1997 Ford Explorer 100000 miles
One of the map light was not working...I removed bulb and replaced with new one. Still did not work. Now I can see that the thin copper looking circuit that is around the light housing is broken. It looks like you can just replace that harness that supplies both lights. How do I remove it w/o causing more problems and also where could I purchase the part?
Thank you in advance for your help.
