Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1998 Nissan Maxima Need...
Auto Repair1996 Nissan Maxima Driv...
Auto Repair2004 Nissan Maxima Ligths
Auto Repair1995 Other Nissan Models
Auto Repair2005 Other Nissan Models...
Auto Repair2003 Other Nissan Models
Auto Repair2000 Other Nissan Models...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Ford Explorer How to clean fuel injectors
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Aug 19, 2008 2:53 am
By jdormon, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
1997 Ford Explorer 6 cyl Four Wheel Drive Automatic 150000 miles
Following the replacement of plugs, leads,coil pack and upstream O2 sensors, I have been advised that the misfire on my Ford Explorer is probably down to clogged injectors and I should have a fuel injection service.
Can you walk me through how to do this and what special tools (if any) are involved? So far my experience of maintaining fuel injection systems has been limited to the mechanical Lucas systems of the 1970's.
Find a car repair manual for your Ford Explorer Repair Question.
Posted at Tue Aug 19, 2008 3:37 am
By mhpautos, Certified 2CarPros Master Technician
Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8Reputation: 515.8 (516) Give Feedback | Votes: 11
Hi there,
Thank you for the donation.
Modern fuel injectors can be cleaned on or off the car, but the equipment needed is normally out of the price range of the home mechanic, (and some workshops as well) they are sealed units and are normally ultrasonically cleaned and then flow and leak tested. some can have the pintle heads replaced, but the quickest option if you want to do this your self is fit re-co change over units, they are normally as good as new and if you are running with faulty injectors they will pay for then self in no time.
Mark (mhpautos)
Posted at Thu Aug 21, 2008 12:44 am
Thanks for you reply Mark, can you give me a little more information on how to remove the injectors and how to check to see if they are functioning correctly or not?
I don't really want to put it back into the shop (been expensive so far, the vehicle is in the UK now and there is a reluctance to work on US models) until I have established what the fault is.
Thanks,
John
Posted at Thu Aug 21, 2008 1:41 am
Hi there,
It is almost impossible to test injectors with out a suitable test rig, and you need to measure delivery and spray pattern, you can listen to them operate, this is just a clicking noise, but you do need the test rig to check for correct operation. As for removal, i will have to find some information on this for you, i will be away for a day or two so don't worry if you don't see anything, i will do it as soon s i return.
Mark (mhpautos)
Posted at Thu Aug 21, 2008 1:53 am
Hi there,
I just came across this info i hope it is of some help.
Mark (mhpautos)
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
