Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Transmission problem
1997 Ford Explorer 6 cyl Four Wheel Drive Manual 100000 miles
My daughter has a 1997 Ford Explorer with the 4.0L engine, 4 X 4. Manual transmission. She has trouble with getting it to shift into reverse and the clutch release bearing seems to make a whining noise. She has had it to Ford 2 or 3 times and had the clutch disc and pressure plate, pilot brg and release brg, as well as the clutch slave cyl. repalced but this does not seem to help.
Some one told her that Ford needed to put shims in someplace to make it work.
Has any one had problems similar to this and if so what did you do about it and has anyone heard of shims for a clutch? I sure never have.
She is a working mother and needs this vechile for work. I appreciate any help that any one can give.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
