Auto Repair Forum - Ask a Question, Get a FREE Answer.
Go Back
1997 Ford Escort misfire code, did tune up and still have p
Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Watch our new
Car Repair Video Series
with Ken Lavacot.
Posted at Sat Jun 28, 2008 7:00 am |
By
lindajessie,
Likes cars! |
(10) Give Feedback | Votes: 0 |
Engine Mechanical problem
1997 Ford Escort 4 cyl Front Wheel Drive Automatic 150000 miles
Last November i had misfire codes cyl.2 +3, did tune up and car went back to normal. Now it is acting up again. Went back to autozone and was told it could be the plugs, that some cars dont like the boucsh plugs, so i had them changes, and timing belt replaced. Still have problems, this time it doesnt always power up, when giving more gas, it stays the same. My father listened to it and said it sounds like a skip in the engine. Not sure what to do now. Will this be extensive work or can i still remedy this with fuel injector cleaner or some other type of solution. Thanks in advance for any feedback.
| Find
diagnostic tools,
replacement parts
or locate a
car repair manual for your Ford Escort Repair Question. |
Posted at Sat Jun 28, 2008 7:03 am |
By
merlin2021,
Certified 2CarPros Master Technician |
                             (600) Give Feedback | Votes: 48 |
You may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs! If that doesnt do it, you may need a new idle air control valve, it's bolted to the throttlebody
Do a compression test on it, 2 and 3 are the middle cylinders, and you may have a leaking head gasket...
| Find
diagnostic tools,
replacement parts
or locate a
Posted at Fri Jul 04, 2008 8:29 am |
By
lindajessie,
Likes cars! |
I changed the coil pack only, used same wires and the symtoms went away. The car is running smoothly now. I can accelerate with no problems. I had the codes cleared before changing coil pack and it was cyl. 1 only misfiring. Last November it was cyl 2+3, and changed coil pack in November too. So, this is the second coil pack for this car. I wonder if there is an issue with coil packs for this car. I have no leaks anywhere. The engine is clean as a whistle, no oil spatters, no vacumm leaks either. Thanks for everything.
| Find
diagnostic tools,
replacement parts
or locate a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
