Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Brakes problem
1997 Ford Escort 4 cyl Front Wheel Drive Automatic 100000 miles
are the front brake rotors separate from the front hub assembly? In other words, can the rotors be replaced without having to disturb the front hubs? Or are the rotors & hubs a single assembly where replacing the front rotors would mean replacing the whole rotor & hub assembly? Thank you for your time & consideration. Jim Honer
FRONT BRAKE ROTOR
Removal & Installation
Remove front wheels. Remove front brake caliper and pads. See FRONT BRAKE CALIPER & PADS . If caliper does not require service, DO NOT disconnect brake hose from caliper.
Using mechanic's wire, secure caliper out of way. Remove rotor from hub assembly. To install rotor, reverse removal procedure. Bleed brakes (if necessary). See BLEEDING BRAKE SYSTEM .
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
