Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Cooling problem
1997 Ford E-Series Van V8 Two Wheel Drive Automatic 111960 miles
i replaced the termoastat flushed the coolant upper radiator hose gets hot lower hose is cold heater core getting hot coolant but still no hot air through the vents
Find a car repair manual for your Ford E-Series Van Repair Question.
Hi:
Does the engine run at a normal operating temp? Also, it's unusual that the lower rad hose stays cool. It should be hotter than the top. Coolant works it's way up through the radiator to cool. If it dropped down, it wouldn't have time to cool before going back into the engine.
Are both heater core lines getting hot and does the engine run at a normal operating temp (around 200 degrees)?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
