Hello –
Need a little more info on your truck. Is it a 1500, 2500 or 3500 and the engine in liter, 5.2L or 5.9L and what is the 8th digit of your VIN. Is this a magnum?
First please go to Auto Zone or O’Reilly’s and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery, alternator and starter.
When was the last time you did a tune up….plugs, wires, fuel filter?
We also need a fuel pressure check.
My first thought with this many miles is your fuel pump. I may be wrong so we need to do the other tests to verify.
Please do the above and provide the information requested and we can take it from there.
Thanks for the donation
Please let us know if what the final fix was for your car so we can better assist others. Thanks!
Find a car repair manual for your car repair questions.
