Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
1997 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
I owned a '97 Dodge Intrepid for awhile. It ran fine but after awhile it felt like the engine was shaking and then finally one day I eased on to the gas and something broke under the hood. now everytime the car runs there is a non-stop clicking noise. everyone says it sounds like the oil pump went out. the car still works but there is still extreme shaking and that non-stop click. anyway, i got rid of that car. it is almost winter now and i JUST have purchased a '97 dodge intrepid sport and whenever i start the car i hear that same click noise that the first one but it goes away within 45 seconds and it even shakes badly too. the wierd thing is that once the car warms up the shaking slows down and eventually stops after awhile. so should i be worried that the same thing will happen to this one? or is it just something that will go away eventually? because no one has told me 100% what that clicking problem is. and i don't know if the cold weather has anything to do with it. maybe the cold is thickening the oil so its hard for the oil pump to deliver oil. but should i be worried about that?
Your car ids fitted with hydraulic valve lifters, these can "tic" when they start to fail, they can also do this if the oil is very dirty and carbon can fowl the lifters, i would do and engine service with a filter and use a good quality engine flush and see if this helps the problem any.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
