1997 Dodge Caravan Transmission vent valve leaking water
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Transmission problem
1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic 118500 miles
when water is poured in radiator, it is leaking back out this vent valve on top of the transmission housing right where the shift linkage is at. Everybody we talk to says no way. The crazy thing is that it is and no idea why.
Sounds like to trans cooler in the radiator is bad and allowing the water to get to the trans. What does the coolant look like? What does the trans fluid look like when you check it?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
