Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic 165625 miles
Van stopped running we were told it was spark plugs and wires. We were able to change all but one plug. Engine starts now but while driving it starts to stall and hitting the gas won't make it pick up speed. While it's idling, the engine sounds like it's running hard and the headlights go dim. Once we get to about 45 mph that's when it will start to slow down by itself and sometimes the engine will just cut off. The one spark plug in the back is impossible to reach, we changed the wire but could that be the problem?
If it is the one the back close to the passenger side, then yes. It is your #1 spark plug. The PCM uses #1 spark plug for timing, fuel delivery and a whole lot of other stuff. If that plug is bad, the whole motor won't run smoothly.
Also, you have OBD-II compliant PCM. Take it doen to Autozone or Checker O'Reilly and have them scan the computer. COme back with the fault code(s).
Yes it is the one back close to the passenger side. For some reason my husband can't get it off. He's tried different tools, took the windshield wiper part off but he still can't get to it. Any suggestions?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
