Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Other Category problem
1997 Citroen C1 4 cyl Two Wheel Drive Manual 44000 miles
where is the petrol fuel filter located on a Citroen AX....THE MODEL ISNT IN THE ABOVE BOX IT IS A CITROEN AX
it is located on the passenger side, under the vehicle tucked up behind the sill .. in-line filter with fuel pipe coming out of each end .. it should be silver but it is probably rusty
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
