Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2001 Mazda Mpv Hose Pop...
Auto Repair1995 Mercury Tracer My ...
Auto Repair1998 Pontiac Grand Prix ...
Auto Repair1998 Dodge Stratus 1998...
Auto Repair1999 Nissan Maxima Fan ...
Auto Repair1991 Mercedes Benz 190e
Auto Repair1999 Acura Rl Power Ste...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Chrysler Sebring ENGINE WILL NOT START
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Aug 26, 2008 11:47 am
By mmrvm, Likes cars!
Give Feedback | Votes: 0
Engine Mechanical problem
1997 Chrysler Sebring 6 cyl Front Wheel Drive Automatic
I just put in new distributor, engine started for about 45 seconds then stoped and wont start again. Engine turns but won't start. I need help on this is my daughters car and needs it for school. thanks
Find a car repair manual for your Chrysler Sebring Repair Question.
Posted at Tue Aug 26, 2008 12:37 pm
By rasmataz, Certified 2CarPros Master Technician
(13) Give Feedback | Votes: 78
Lets try below and see what happens if its fuel or spark
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
Posted at Tue Aug 26, 2008 2:44 pm
There is no spark. That was the reason I was told to change the distributor. Will the cam or crank sensor make the car not start? I put in the throtle position sensor, the distributor cap and rotor and no spark, then I put the distributor and thats when it started for 45 seconds and stoped and no spark again. What next? thanks for your help
Posted at Tue Aug 26, 2008 3:26 pm
Inspect and test the cam and crankshaft sensors
Posted at Wed Aug 27, 2008 4:31 pm
Its strange because I sprayed starting fluid and it starts. I checked the fuel pump and it works perfect. Could it be the voltage to the injectors? if so How would I check the voltage to the injectors?
Thanks for your help.
Posted at Wed Aug 27, 2008 4:35 pm
One of the wire on the injectors should have battery voltage the other is the driver ground circuit-check it out or use a noid light and crank engine over is the light flashing?
Posted at Wed Aug 27, 2008 4:38 pm
Check the injectors resistance with an ohmmeter if its within specs-could be an injector shorted out and dragging the rest down-
Posted at Wed Aug 27, 2008 4:50 pm
I just checked for voltage at the injector and there is no voltage at all. I put a test light and no voltage, crank the engine and nothing. what is causing that? what next?
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
