Electrical problem
1997 Chrysler Cirrus 4 cyl Front Wheel Drive Automatic 162400 miles
To start, this is my 2nd car and I'm quite sure I know how to install an aftermarket deck.... on top of that I have helped many friends install their radios with no problem. So, you could understand my worry when I went to install my radio and it didn't work. I got most of the wires hooked up but couldn't find a ground wire. I did research and found out there isn't one and I had to attach it to a screw. I also checked every single fuse in that car a billion times. All are good. So just to recap, I have all fuses working and all radio wires connected to the proper wires coming from the car, and yet my radio still wont work or turn on or anything!!!
