You need to reset the alarm off. When the alarm/horn went off, it sent a disable signal to your fuel pump circuit. That is why you have power at the relay, but not at the fuel pump connector.
Unfortunately, different alarm manufacturers have different ways to reset their respective units, you have to research the brand, and find out how to reset it.
Most alarm system connections are done under the steering column.
