We are the Car Repair Experts!
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1997 Chevy Van Chevy Van no start condition.
Posted at Mon Nov 02, 2009 2:50 pm |
By
two66mhz,
Likes to hang around! |
(12) Give Feedback | Votes: 0 |
Electrical problem
1997 Chevy Van V8 Two Wheel Drive Automatic ? miles
I have a Chevy 2500 Van with a 5.7L engine that cranks but not start. I confirmed spark and compression. I found no power to the fuel pump and had no pressure (obviously), I measured the voltage at the fuel pump relay found 12v on pin 87 (Org/B1), I have 0v on pin 86 (Green/White wire) the Fuel Pump Relay Feed from the VCM. I have good grounds at the relay. I tried jumping 12v battery power to 87a (GRY/A3) wasn't able to confirm fuel flow from the pump (I couldn't hear it pumping). I did test the relay and all checked out. Any ideas I still have to look at the oil pressure sender. Until tonight when I have the proper tools to get to it.
Any ideas??? |
Find a
car repair manual for your Chevy Van Repair Question.
Posted at Mon Nov 02, 2009 3:32 pm |
By
rasmataz,
Certified 2CarPros Master Technician |
                            (14570) Give Feedback | Votes: 346 |
Power the fuel pump connector gray wire from the battery, did the fuel pump come on? |
Find a
Posted at Mon Nov 02, 2009 4:04 pm |
By
two66mhz,
I could not confirm the pump at that time. I tried to start the vehicle and it wouldn't. Going to be back at the vehicle later tonight to take the doghouse off. I figure I should've been able to hear the pump. I will repost tonight once I know for sure that the pump wasn't turning on. |
Find a
Posted at Tue Nov 03, 2009 1:34 pm |
By
two66mhz,
| rasmataz wrote: | | Power the fuel pump connector gray wire from the battery, did the fuel pump come on? |
Okay, so I made a connection to the fuel pump with a 10 amp jumper wire i made, I confirmed that the voltage is getting to the pump. I had the fuel filter lines disconnected when I energized the circuit and to no avail I had no fuel flow... I confirmed the ground which had 3-4 ohms of resistance. Also confirmed the 2 sec feed from the ECM/VCM. So I'm thinking I should possibly be replacing the pump. But I would like a second opinion, there is still something in the back of my head thinking that the oil pressure sender could be causing this. But after jumper`n the fuel pump and not getting anything, ARGG. I would just like to be sure in my head. I'm thinking too much. |
Find a
Posted at Wed Nov 04, 2009 7:18 am |
By
rasmataz,
You got battery voltage and a good ground it should fire up w/o the oil pressure switch when direct battery voltage being applied |
Find a
Posted at Wed Nov 04, 2009 7:55 am |
By
two66mhz,
| rasmataz wrote: | | You got battery voltage and a good ground it should fire up w/o the oil pressure switch when direct battery voltage being applied |
That is what I thought or at least puymp fuel all over the ground which it didn't do that either. I guess I just didn't wish the pump to be bad @ $528+tax. Thanks for helping. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
