Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2000 Nissan Maxima Front...
Auto Repair2005 Audi A6 Car Can't D...
Auto Repair1992 Nissan Maxima Chugg...
Auto Repair2001 Nissan Maxima
Auto Repair2007 Toyota Corolla Fuild
Auto Repair1996 Nissan Maxima Car C...
Auto Repair1994 Nissan Maxima
Auto Repair2004 Nissan Maxima Cars ...
Auto Repair1985 Ford Bronco I'm Goi...
Auto Repair1995 Nissan Maxima Radia...
Auto Repair1998 Mercury Marquis Car...
Auto Repair1997 Nissan Maxima Air C...
Auto Repair2004 Dodge Caravan Hesit...
Auto Repair1998 Nissan Maxima All K...
Auto Repair2001 Nissan Maxima Front...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Chevy Suburban 97 suburban 5.7L boggs down
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Fri May 16, 2008 6:54 pm
By brichart, Likes cars!
Give Feedback | Votes: 0
Engine Performance problem
1997 Chevy Suburban V8 Two Wheel Drive Automatic 205000 miles
my suburban boggs down severly when driving and when reving in park or neutral. I have done multiple things to correct this problem to include, new plugs, plug wires, distributor cap and rotor, new spider injector, compression test, fuel pressure test, and finally dissabled the cats to see if they were plugged up. I also checked for vacuum leaks with propane and found none. The plugs are sparking fine and the gaps are good, however, I keep getting a number 6 cylinder misfire code and a left bank oxygen sensor code. That oxygen sensor was replace about a month ago. It started out gradual but has progressed to the point where it is near impossible to make it up a hill. Any one have a clue what else to try? Any suggestions would be greatly appriciated.
Find a repair manual for your Chevy Suburban Repair Question.
By Advertisment,
Posted at Sat May 17, 2008 12:37 pm
By blackop555, Certified 2CarPros Master Technician
Reputation: 132.3Reputation: 132.3Reputation: 132.3Reputation: 132.3Reputation: 132.3Reputation: 132.3Reputation: 132.3 (132) Give Feedback | Votes: 24
exhaust leak on the side of the bad o2 sensor can cause it, also if your MAF sensor is bad it could be causing this problem, clean it with qd contact cleaner.
205,000 miles? perform a cylinder compression test wet and dry on all cylinders, make sure the readings are within specs.
Posted at Sat May 17, 2008 4:29 pm
thought about that too, the o2 sensor code is on the opposite bank of the misfire. also had compression test done by reputable shop in town and they were good. Same shop said the MAF sensor is reading good. Wondering now if the computer could not be advancing the timing correctly?
Posted at Sat May 17, 2008 4:56 pm
pull the jumper for the advancement, same jumper used for setting the timing.
might have to take it in and have the cross fire checked on it with the scan tool.
Check EGR valve also, could be plugged atad, PCV valve good? double check.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
