Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1994 Nissan Sentra Froz...
Auto Repair1986 Cadillac Deville M...
Auto Repair1995 Ford Taurus Loss O...
Auto Repair1999 Chrysler 300
Auto Repair2006 Gmc Sierra Shuts O...
Auto Repair2007 Hyundai Santa Fe
Auto Repair1998 Mitsubishi Eclipse
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Chevy Silverado Fuel Delivery Problem
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Thu Sep 04, 2008 10:42 pm
By silverado8527, Have Donated
Give Feedback | Votes: 0
Electrical problem
1997 Chevy Silverado V8 Two Wheel Drive Automatic 123k miles
My Silverado has SFI and I recently have had to prime the bowl with a drop of gas to start it upon which it ran fine. Finally I stalled doing 35mph. Upon inspection I noticed a lack of fuel pump buzz when cranking. I found a blown ecm b fuse under the hood which turns out to be power to the pump. However, replacement did not bring back the buzz Ive always heard from inside the cab, but it is audible when you crouch next to the tank. I assumed it to be a bad pump so I dropped the tank and removed the pump. I did a volume test i read about where as it should pump at least a quart in 30 seconds, which it does easily. There is fuel getting up to the motor because i get fuel at the pressure valve. The injectors must be ok because upon priming it it ran fine. Now it will start with a prime and stall right away. What is missing is hearing it kick on for two seconds from INSIDE the truck. Is this a sign of a pressure problem?
Any suggestion would be greatly appreciated.
Note: I replaced filter when starting first became problem, did not help. Also checked pump circuit for low voltage, bad relay etc.
Find a car repair manual for your Chevy Silverado Repair Question.
Posted at Fri Sep 05, 2008 5:35 am
By Docfixit, Moderator
Reputation: 131.9Reputation: 131.9Reputation: 131.9Reputation: 131.9Reputation: 131.9Reputation: 131.9Reputation: 131.9 (132) Give Feedback | Votes: 5
Hi
You need to check fuel pump pressure it should be 52 to 62 psi. Flow test is not an indicator of pressure. Check the relay underhood relay box the red wire powers pump check voltage.
Check pressure and let me know
Thanks for your donation
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
