Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2001 Mazda Mpv Hose Pop...
Auto Repair1995 Mercury Tracer My ...
Auto Repair1998 Pontiac Grand Prix ...
Auto Repair1998 Dodge Stratus 1998...
Auto Repair1999 Nissan Maxima Fan ...
Auto Repair1991 Mercedes Benz 190e
Auto Repair1999 Acura Rl Power Ste...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Chevy Monte Carlo 97 Monte Carlo Strange Start-up
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Goto page 1, 2  Next
Posted at Fri May 23, 2008 9:09 am
By bbowen87, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
1997 Chevy Monte Carlo 6 cyl Front Wheel Drive Automatic 104000 miles
I've had the car for about 3 years now, have not run into this current problem.
The Problem: After I start the car, it stutters, like you can hear the air puttering every 2 seconds or so. During this time, the lights are all dim, and it sounds like it is going to stall, but it doesn't. I let it go, it rev's up to 3,000 RPM, without me touching anything, just starting it up. After sitting there for about 10 seconds, it slowly starts to lower down to 1,000 RPM, then back to the stuttering. It continues in this cycle, over and over.
I have not left it on for more than a minute, and am too afraid to drive it.
Find a car repair manual for your Chevy Monte Carlo Repair Question.
Posted at Fri May 23, 2008 9:35 am
By merlin2021, Certified 2CarPros Master Technician
Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9 (635) Give Feedback | Votes: 51
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it to Autozone, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on...
Posted at Fri May 23, 2008 9:58 am
Ok, decided to attempt to drive it, it drove fine to autozone (luckily for me, a block down the road)
There was no Check System message, so the scanner did not show any codes, the clerk told me.
Only thing I noticed when watching him scan it, was that there was no reading from the TPS? Could that be a factor?
Posted at Fri May 23, 2008 10:14 am
I'm not sure about the scantool they use, I only know they do it free...a bad TPS will cause poor driveabilty, so wont other parts, let me look yous up and see if I can get voltage readings you can refer to...
Posted at Fri May 23, 2008 10:30 am
Your symtoms seem more like either a vacuum leak...large one, or the idle air control, or worn throttlebody throttle plate or shaft. Try cleaning the throttle body, then get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs!
Posted at Fri May 23, 2008 11:06 am
Will try this, ty for the speedy responses, will get back to you when i get to the store to buy it.
Posted at Fri May 23, 2008 11:22 am
After inspecting the engine with the hood up and car running, I found a cracked tube, and the sound of air rushing out of a balloon coming from that area, is there a temporary fix to the tube (certain tape i could use?) to seal it until i have the money to replace it?
It's a tube going to the main block connected to where my water pump is.
Posted at Fri May 23, 2008 11:32 am
Can you post a digital camera picture? Is it a water or air line?
Posted at Fri May 23, 2008 11:35 am
I can definitely take a photo, but it would have to be tomorrow, I have to work 4-9, i will def. keep this updated with a photo tomorrow morning, by the time i get home it will be dark, or id post it tonight.
After taping it, (its an air line), i listened in more closely, and it seems to be coming from more toward the back of my engine, like a spot where they would actually have to pull the engine out, seeing as the engine barely fits in there as it is.
I will take a photo and edit where i am hearing the sound from tomorrow morning.
Posted at Fri May 23, 2008 11:48 am
See you then!
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
