Free Car Repair Advice by Certified ASE Technicians
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1997 Chevy Lumina after transmission flush, car hasnt opera
Posted at Sat Nov 07, 2009 10:28 pm |
By
zodiacdude,
Have Donated |
(10) Give Feedback | Votes: 1 |
Shakes or Wobbles problem
1997 Chevy Lumina 6 cyl Two Wheel Drive Automatic 147800 miles
After I had my transmission flushed (and my tires rotated) back in Sep, my car doesnt feel as smooth of a ride as it was before. I've since had my tired balanced (and retorked) which has helped a little, but I still notice some shaking and I can feel the shaking and stiffness in the steering still.
Right after i had the transmission flush, about 5 mins later on the road, I tried to accelerate, and the dial went over to 4 (4000 rotations a mintue), but the engine barely accelerated. That has happened a few times this past year as well, so i dont know if this is a continuation of that, or if this is a separate issue. |
Find a
car repair manual for your Chevy Lumina Repair Question.
Posted at Sun Nov 08, 2009 5:33 am |
By
Service Writer,
Certified 2CarPros Master Technician |
              (7324) Give Feedback | Votes: 98 |
Regarding the slipping. Transmission is probably on it's way to a rebuild by the sounds.
List the mileages at which the fluid and filter have been changed.
Is the trans original? If not how many miles are on it?
Regarding the stiffness: Possible strut mount, ball joint or tie rod end issue would be my first thought assuming the power steering fluid is full.
Raise the front of car up and turning the front wheels
by holding one wheel by the nine and three position.
IS it smooth? Does the spring jutter in the mount as you are turning it? Is it overly stiff?
Regarding the shaking:
Feel the tread of the tire by running your hand around the circumference of the tread in one long pass.
Is there a smooth kind of feel?
normal
Is there any charactoristics that are not smooth?
Abnormal.
One such possibility:
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
