Car Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1997 Chevy Lumina AC blows regular air, but no cold air
Posted at Sat Nov 07, 2009 10:16 pm |
By
zodiacdude,
Have Donated |
(10) Give Feedback | Votes: 1 |
Air Conditioning problem
1997 Chevy Lumina 6 cyl Front Wheel Drive Automatic 147800 miles
The heating in my car works, but not the A/C. I took it in a few years ago to have it checked out, and Firestone said that they tested it and it worked ok for a little while, but then it died out. They said I didnt need a whole new A/C unit, but I needed some part that I can't remember the name of now. Any idea what part that would be? |
Find a
car repair manual for your Chevy Lumina Repair Question.
Posted at Sun Nov 08, 2009 5:36 am |
By
BMRFIXIT,
Certified 2CarPros Master Technician |
                (8515) Give Feedback | Votes: 85 |
AC system is a complicated and easy at the same time
1st you need to know if the system holding in the refrigerant or if its leaking
if leaking have to check and find the leak and repair the area
many methods can be used to find the leak ,this is some
Bubble Solution Detector
This is a solution applied externally at suspected leak points. Leaking refrigerant will cause the detector to form bubbles and foam. A soap and water solution also works well.
Dye Solution
This is a colored solution that may be introduced into the A/C system. The dye will show up and color components at leak points. Some manufacturers offer refrigerant containing a Red dye. This dye-containing refrigerant is installed by normal charging procedures. Other dye solutions are visible with a Black light only.
Electronic Detector
This instrument will draw in any leaking refrigerant through a test probe, and then sound an alarm or create a flashing light if refrigerant is found. It is the most sensitive of the leak detectors used
if system if holding and no leak
know you have to check if the AC compressor coming on and what you have for pressure on low and high side
need to use a set of manifold gauges
if this part of the system check OK
know we move on to the HVAC box and the blend operation
and have to check if the blend door operating and the actuator function |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
