Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Brakes problem
1997 Chevy Express 6 cyl Two Wheel Drive Automatic 89120 miles
simple brake job gone bad. changed front pads, cut rotors. done good to go, went to test veh no brakes to the floor glided to a stop. Checked rear drum brakes everything good, changed master cylinder,and calipers. problem still exsist. Brake fluid dirty, flushed system. no improvement
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
