Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Hi:
Follow the upper rad hose back to the engine. It will be attached to the thermostat housing. Drain the coolant, remove the hose from the housing, unbolt the housing and remove the t-stat. reverse the order to replace.
Hi:
Joe,
Many thanks for the response, but I must beg to differ.
At first, I did exactly what you described and guess what - NO stat! My initial thought was that the previous owner removed it in a lame attempt to cure a cooling/heating issue. No problem, right?
Upon closer inspection I found the curious words "thermostat at water pump" stamped into the fixture attached to the upper hose that I had already unbolted from the block. I then traced the lower hose back under the exhaust manifold to what I assume is the belt-driven water pump.
The thing is, in addition to being difficult to get at (thanks Chevy!), there are two separate fixtures between the lower hose and the water pump.
Which one is the thermostat in, or do I have to remove both of them to complete the repair?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
