Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1996 Mazda Millenia Eng...
Auto Repair2002 Ford Taurus
Auto Repair1998 Toyota Camry 1998 ...
Auto Repair2002 Ford Focus Blower ...
Auto Repair2001 Mazda Miata Obd 2
Auto Repair1991 Chevy S-10 Stalls
Auto Repair1999 Oldsmobile Alero I...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Chevy Astro Engine Missing random multiple misfires wh
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Thu Jun 05, 2008 6:59 am
By hkypuk6, Likes cars!
Give Feedback | Votes: 0
Engine Performance problem
1997 Chevy Astro 6 cyl All Wheel Drive Automatic 184615 miles
First, here's what I have recently done: Changed sparkplugs and sparkplug wires twice, changed distributer cap & rotor, had MAP sensor tested (good), had fuel injectors cleaned, replaced PCV Valve, Fuel filter, new fuel pump (was missing before fuel pump went out), had catalytic converter cleaned out. I have also just purchased a new Ignition Coil, but I have not installed it yet.
Problem: Service engine light is on. Sometimes goes out, sometimes flashes then stays on. Scan code shows "Random multiple misfires" (forgot actual code #). Engine runs really rough (missing) especially when taking off from a stop until it get's into (I believe) 3rd gear. It helps to let off the gas pedal until it shifts. It also sputters or miss big time when traveling at higher speeds (60-75). Some days are worse than others...but it's now missing most of the time.
I'm running out of ideas as to what is causing this problem. The engine has backfired a couple of times, but it hasn't backfired lately. I now also have a muffler leak. I'm sure this is a cause/effect case. The bottom line is that I need to get the engine mis-firing taken care of before this causes any more problems.
Ideas?
Thanks much......mrb
Find diagnostic tools, replacement parts or locate a car repair manual for your Chevy Astro Repair Question.
By Advertisment,
Posted at Thu Jun 05, 2008 2:02 pm
By Astro Mystery, Likes cars!
I have the exact same Astro with the same problem and have tried most of the things you did.. Every 1 to 6 months the engine starts to stumble. It can be so bad sometimes it can hardly make it up a small hill. When I change the Cap & Rotor it runs fine and I can't see anything wrong with the old ones. I never find moisture in the Cap but I have tried drying it out and cleaning it but this makes no difference. Only when I replace the Cap & Rotor is the problem solved until the next time. Sometimes I think it stumbles after it has been in the rain but for the most part it goes into the dry garage every night. Also, I did buy a bad Cap & Rotor once and had to exchange it. I never figured out what was wrong with it, no visible defects or damage. It just did not work. I have no idea what's eating the Cap & Rotor or what's happening to them that forces me to replace them, but this works for me. It takes me longer to take that damn dog house off to get at the distributor then it takes to change it. I hope this helps somewhat or at least you know you're not alone. I've been trying to get an answer to this for 3 years but know one has a clue. I would appreciate it if you get a more decent answer that you let me know. Thanks!
Posted at Thu Jun 05, 2008 2:40 pm
Thanks for your response. I also have pretty much done the same as you and had very similar results. As far as the dog house goes...I have forgotten what it's like to have the center console cup holders and small glove box. I only have the firewall cover on. Got tired of continuously taking the other off all the time. Now it's a lot quicker to get to! Whenever I change the cap & rotor out, it definately gets much much better, but I can still feel a bit of missing. Definately not near as bad. I also think this problem is killing my catalytic converter from what I have read in other places (which is fairly spendy). I have seen other's with this problem, but no one really has an answer, the answers all varied. I did see in one location where someone was suggesting that the problem was a bad seal on the Distributer mount and recommended getting a new distributer, but I haven't seen any other similar recommendations and/or results of that, so I have hesitated in spending the $90 for a remanufactured Autozone replacement in "hopes" that it fixes it. If I saw more indication of that being the problem, I might go ahead and try it....I keep putting it off.
thanks
Posted at Fri Jun 06, 2008 10:43 am
Thanks much for getting back to me. I no longer feel all alone with this mystery. Let me share with you some of the info I have found and perhaps together we can once and for all end this costly / time consuming Astro maintenance nightmare so we can both get our cup holders back. Sorry if this is a bit lengthily but detail matters. This problem started for me at around 110,000 miles. Before that all was fine. The first misfire experience I had was a bad Ignition Coil that was arcing like the 4th of July. I replaced it and about 1 year later it failed too and was arcing again. This one lasted 1 week and vehicle died on the road. That Coil did not arc it shorted out and quit, (off-the-shelf part failure). I replaced it and its been fine ever since. About 8 months later it started misfiring again but it was different. Coil was ok and after a long trouble shooting process I discovered the Distributor Cap was bad. I changed it, it ran great, it made on sense, couldn't figure out why. 8 months later, misfire again, changed Cap and problem solved. 4 months goes by and again misfire. Changed the Cap, misfire was worst. Now it was driving me NUTS. I got another Cap and misfire was gone, again (off-the-shelf part failure). I have gone through 6 or 7 Caps in the last 3 years, expensive and time consuming. I just changed it again 2 days ago. I kept the last 3 bad Caps and tried different things looking for change. I found that each Cap caused a different feeling misfire. Like different cylinders were effected by each Cap. I drilled a 1/2" hole in the side of each Cap so I could see spark when it was running. Sure enough the spark would change color and each Cap had a different spark pattern to it. These Caps are shorting out over time and not the same way. I would always buy the next Cap made by a different manufacturer trying to find a better quality Cap. Have not found one yet. I buy all my parts from reputable auto supply businesses that all the local mechanics use. Their experience like mine is a higher off-the-shelf part failure rate mainly in the last 8 or 10 years and getting worst. I never buy parts from places like Auto Zone or Advanced Auto because they are like Home Depot and Wal-Mart. They buy huge quantities, demand the suppliers to lower the cost because of purchasing power, the manufacturer cuts quality to make up the difference and we the public suffer for it. So, back to the Caps. Check out these links, I think you'll fine them informative.
http://www.napaechlin.com/web_app/DYK/download/DYK-GMVortecDistributor.pdf
http://www.tomorrowstechnician.com/Content/Site301/SmartProducts/PATTERNFAILURES_00000000860.pdf
I would really like to keep a dialog with you about this if that's ok and perhaps get off this forum. My name is Tony and my e-mail address is tlea2nd-1@yahoo.com You are the first person I've found with this identical problem and I really want to end this nightmare. Thanks, Tony. The guy desperately in search of a quality manufactured Distributor Cap.
Posted at Fri Jun 06, 2008 1:34 pm
Sounds good to me! I'll email you directly. Looking throughout this forum, I see a lot of lookers but I don't see a lot of help. There are many questions that folks have with no replies. Just a lot of lookers!
thanks
Posted at Wed Jun 18, 2008 5:58 am
By security101, New to the forum
VERY INTERESTING!!!! I have the same issue exactly! only mine finally backfired and died last winter. I had replaced the cap (again) just prior to the "backfire event" and just figured it couldn't be another cap...
I had a certified mechanic come by and he said the backfiring could only happen with timing chain issues, that the deposits and constant replacing of the rotor/cap was from the chain allowing slack which altered the spark.
So it's sat until now as I tried to sell a "no start" for 5-700 bucks!
By the way it's a 97 Astro v6...
I would also like to email you and see what your finding out, wow - wouldn't it be cool if I could solve it with just a "better Brass" cap and some filter cleaning...
Jim
Posted at Thu Jun 19, 2008 1:19 pm
Jim, I'm sorry to hear that you are having a lot of the same issues. It's interesting that it seems that there are many vans out there with the same issue, but no one has yet to find a solution. At least that I'm aware of.
I am currently still troubleshooting my van's problems. I have just purchased "another" dist. cap (AC Delco) that I'm about to install. The word on the street, that I keep hearing, is that the AC Delco dist. caps appear to have the best and longest results with these vans.
I'd be happy to hear some of your results of troubleshooting also. Please drop me an email at the following address: mrbjunkbox1 at gmail.com
Mike
Posted at Thu Jun 19, 2008 2:26 pm
Hi Mike,
I have tried everything everyone else has to no avail - 6th cap (many have been AC Delco as this was recommended a ways back) and still have issues.
I had all but givin up and was in the process of selling the van (97 Astro) for $700 bucks (well below KBB) as it is clean, everything else works (except the rear door latch) and I gave up on it (and everybody had an opinion like: "fuel pump" which I'm on my 3rd probably for no good reason) - when I came across this thread on a related Google search!!
I had researched this heavily and found no similar threads or explanation for the problem. So about 5 mos ago, the day after my daughter bought her first new (junker) car - I, as the "bad Dad", commandeered it, and have drivin it since (don't worry I still take her everywhere she has to go!). She's told me to vacate it as she's turnin 18 and I'm looking for something for me to drive.
SO sell the Astro add 1k and go by me a junker - right?
Nope, I found you good folks chattin about "my issues" and it looks like I better revisit the old Astro before some "wiz kid" straight out of mechanics class buys my van, throws a new distributor/cap/rotor in it and squeezes the last 20,000 miles out of it!!!
ANYWAY...
I called the local dealer service dept this morning and spoke with "Darrell" and you wouldn't believe it but he said he knows about this issue. He has "fixed a bunch of them" and it's easy...
Replace the distributor, bottom line!
He said the "vent issue" is prominent (I explained I didn't think that was MY issue - but I dunno) and he also said there was mechanical issues with the "old style" yet he wasn't clear exactly what physically is different. He's just been replacing them and all is well.
One other note, the last time it "pooped out" it also backfired when I was trying to start it and when we tried the old cap replacement, and could never get it to go again (I could get it to idle, but just touch the pedal and it died). Hopefully the timing chain didn't go (anyone with an astro knows that is a "more major" job than on most vehicle's) cause I'll just sell it as a "no start" before I put that kinda effort back into it!!
Anybody got a cheeeep Kia??
Jim
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
