Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1995 Chevy Corsica Radi...
Auto Repair1998 Dodge Neon Changin...
Auto Repair1998 Plymouth Breeze Va...
Auto Repair2000 Chevy Cavalier
Auto Repair2000 Dodge Intrepid Rou...
Auto Repair1985 Chevy Bel Air Inte...
Auto Repair1999 Plymouth Breeze Quits
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Chevy Astro charging system
Welcome to our question and answer forum. We answer over 6,000 free and donated auto repair questions every month. All you have to do to ask a question is to signup to our forum.
Asking a question is free of charge and your question will be answered by one of our non-certified forum users for free. You can however elect to donate to make sure your question gets an guaranteed and professional answer by one of our many 2carpros certified repair technicians.
Questions with donations are answered as promptly as possible. Due to the nature of car repair problems, some take longer to solve than others. We are confident that you will be better informed regarding your problem and will have an good idea of what direction your repair needs to go after we have answered it. If you have donated and were unsatisfied with our effort we will gladly return your donation. We help thousands of people every month and want to help you too. Sometimes it requires some dialog between our technicians and you to get to the bottom of your problem. 100% of the donation is awarded to the technicians helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Tue Jun 24, 2008 11:09 am
By ivanfamily, Likes cars!
Give Feedback | Votes: 0
Electrical problem
1997 Chevy Astro 6 cyl Two Wheel Drive Automatic 108000 miles
My alternator was making noise and starting to burn the serpentine belt. I bought a used alternator, which did not seem to work. I have exchanged it twice, and the car is still not charging. I checked with a voltmeter, and there is about 13 volts coming out of the battery terminal on the back of the alternator. There is a battery fuse and an upfit battery fuse, both of which appear to not be blown. I tested these fuses with an ohm meter and found no resistance across the fuses. The positive battery cable coming from the fuse box to the battery also shows no resistance, and the negative cable from the battery to the frame shows no resistance. The replacement alternators I have gotten all have a four prong outlet, but the connector plug on the van is a two prong. I traded the original alternator in for the replacement one, and I did not notice if it had a two prong socket, but everyone assures me that the alternator for that model is a 4 prong. The two prong will fit on the middle two prongs, but the battery is not being charged, and the lights go dim, and the car stalls. Any ideas?
Find diagnostic tools, replacement parts or locate a car repair manual for your Chevy Astro Repair Question.
By Advertisment,
Posted at Thu Jun 26, 2008 11:13 am
By jdl123, Tech level 3
(13) Give Feedback | Votes: 0
With everything turned off, you have bat voltage at the bat terminal on the alternator?
The two terminals at the alternator plug, are they hot, with the engine running? The lamp terminal is the brown wire and the field terminal is the gray wire. On the field terminal, it should be a duty cycle type pulse.
The info I looked at was for two wires at the wiring connector even though the alternator may have a four terminal socket.
Posted at Mon Jul 07, 2008 5:15 pm
There is only voltage coming from the alternator's bat terminal when engine is running. There is no voltage coming from either of the two wires at the plug. Any ideas? Thanks, George
Posted at Wed Jul 09, 2008 12:46 pm
What are the color of the wires at the connector that plugs into your alternator? Some of my info only shows one wire, besides the bat terminal.
I did find an astro with a two wire alternator plug, but that was a different year, not a 97.
Posted at Wed Jul 09, 2008 6:11 pm
One wire is black and the other one is gray with a black stripe.
Posted at Thu Jul 10, 2008 9:32 am
My information doesn't show those wire colors.
Does the alternator connector have letters for the terminals? Is the L terminal hot with the connector plugged in and the engine running? Do you have a charge lite indicator on the dash, does it ever come on?
If that terminal isn't hot check the gage fuse. Not only check the fuse, check that the circuit, that fuse plugs into, goes hot when you turn the key on. Usually there is a bare spot on top of the fuse where you can check for voltage.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
