Engine Mechanical problem
1997 Chevy Astro 6 cyl All Wheel Drive Automatic 95000 miles
The Astro Van has an oil pressure problem when the engine reaches operating temperature. When the engine is cold the oil pressure is approx 50 psi at driving speed (a little lower at idle). When the engine heats up ithe oil pressure is approx 30 psi at driving speed. When the van is stopped at a light and the engine goes to idle the oil pressure drops to 3 to 5 psi (check gauges lite comes on). I have replaced the pressure sending unit and switched to Mobil 1 10-30 synthetic oil with no change. Since I do not have a tack I do not know what the idle speed is. Is there any possible problem other than replacing the oil pump which is $950.00 at the dealer
Find a
repair manual for your Chevy Astro Repair Question.
This could be a faulty pump. a faulty pressure relief valve or a very worn set of engine bearings. Just putting in a new pump may be just a band-aid solution, i would have the engine inspected for serviceability and if badly worn, i would not be spending money on just a pump.
Mark (mhpautos)
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins.Click
here to find out more.
