Auto Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
1997 Chevy Astro Ignition system
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Mon Dec 01, 2008 1:57 pm |
By
kamy453,
Likes cars! |
Give Feedback | Votes: 0 |
Electrical problem
1997 Chevy Astro 6 cyl Two Wheel Drive Automatic
My car starts but does not turn on the engin, I replaced rotor, distributer cap, spark plug, spark plug wires, ignition coil and module but there is no spark from ignition system, my question is how can I check the VCM(vehicle control module) and ignition signal sensor or what is my problem?
Thanks
Kamy
| Find a
car repair manual for your Chevy Astro Repair Question. |
Posted at Tue Dec 02, 2008 5:36 pm |
By
kamy453,
Likes cars! |
Hello
Thank you for response, yes when I turn on the switch(without starting the car) one leg of two legs of ignition coil cable with body (ground) has 12 volts DC, when I do the same also I start the engine both legs of ignition coil cable together give me 12 Volts DC, but when I keep the high Voltage cable from ignition coil next to body (ground) and the same time start the engine no blue spark from cable.
Thanks
| Find a
Posted at Wed Dec 03, 2008 7:36 am |
By
kamy453,
Likes cars! |
Thank you for response, I try to use the old one it was the same, also I checked the new ignition coil by ohmmeter and instruction from a repair manual book, the amount of ohm between primary and secondary connector are correct, how about pick-up coil (location is inside of distributor), is there any chance that is a problem?.
Thanks
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
