Free Car Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1997 Cadillac SLS codes
Posted at Sat Oct 17, 2009 9:44 am |
By
dirtdiver,
Have Donated |
Give Feedback | Votes: 0 |
Computer problem
1997 Cadillac SLS V8 Two Wheel Drive Automatic 109000 miles
obd2 scanner brings up po171andpo174saying the car is running lean.i check fuel injectors for leaking and clogged they seem to be o.k.if it is a oxygen sensor gone bad i have three how will be able to tell which one is the problem. thanks for helping. |
Find a
car repair manual for your Cadillac SLS Repair Question.
Posted at Sat Oct 17, 2009 10:00 am |
By
BMRFIXIT,
Certified 2CarPros Master Technician |
                (8527) Give Feedback | Votes: 85 |
Check vacuum hoses for splits, kinks and proper routing. Check throttle body, air induction system after MAF sensor, intake manifold, PCV and EGR valve for vacuum leaks. Check for contaminated fuel. Ensure PCM grounds are lean and tight. Check for mechanical failure. Repair as necessary |
Find a
Posted at Mon Oct 19, 2009 2:12 pm |
By
dirtdiver,
Have Donated |
I did what BMRFIXIT and the forum said to do, but my results were the same. The check engine light is still on. What do I do now? |
Find a
Posted at Mon Oct 19, 2009 2:28 pm |
By
BMRFIXIT,
I obtained this TSB and will share it with you hope it will help let me know
Affected Model(s):2006 and Prior All General Motors Passenger Cars and Trucks; 2003-2006 HUMMER H2; 2006 HUMMER H3
Supercedes:This bulletin is being revised to add models and model years and update the name and part number of GM Fuel System Treatment. Please discard Corporate Bulletin Number 04-06-04-051A (Section 06 - Engine/Propulsion System).
Related Ref Number(s): 04-06-04-051, 04-06-04-051A, 04-06-04-051B
ARTICLE BEGINNING
SERVICE INFORMATION
General Motors is aware that some companies are marketing tools, equipment and programs to support fuel injector cleaning as a preventative maintenance procedure. General Motors does not endorse, support or acknowledge the need for fuel injector cleaning as a preventative maintenance procedure. Fuel injector cleaning is approved only when performed as directed by a published GM driveability or DTC diagnostic service procedure.
Due to variation in fuel quality in different areas of the country, the only preventative maintenance currently endorsed by GM regarding its gasoline engine fuel systems is the addition of GM Fuel System Treatment PLUS, P/N 88861011 (for U.S. ACDelco®, use P/N 88861013) (in Canada, P/N 88861012), added to a tank of fuel at each oil change. Refer to Corporate Bulletin Number 03-06-04-030G, VARIOUS DRIVEABILITY SYMPTOMS DUE TO CLOGGED FUEL INJECTORS, MIL/SES DTCS P0171, P0172, P0174, P0300, P1174, P1175 for proper cleaning instructions. |
Find a
Posted at Mon Oct 19, 2009 9:24 pm |
By
gstacey,
Moderator |
(174) Give Feedback | Votes: 36 |
If both banks are setting lean codes, and the fuel trim values are indicating lean, it has to be an air leak that is centrally located. Some possibilities include the vacuum source line for the HVAC at the right of the intake(belt end of engine), there is also a relief valve with a spring loaded door on that end that releases pressure during backfire. The mass airflow sensor could also be faulty and indicating more air than is actually entering engine. There could be an air leak after the mass airflow sensor resulting in unmetered air. The chance that your injectors are equally restricting flow to result in lean conditions are minimal. The fuel pressure could be low, I would think you would have other problems as well. |
Find a
Posted at Tue Nov 03, 2009 3:02 pm |
By
dirtdiver,
Have Donated |
GStacey and BMRFIXIT:
Thanks a million for your info on how to fix my problem! It's been 2 months that I have been trying to fix it and you saved me! It was right you said it was by the HVAC replace vaccuum lines which cost 2 dollars. You guys saved me a diagnostic cost as well. Thanks again!
DirtDiver |
Find a
Posted at Wed Nov 04, 2009 4:12 am |
By
BMRFIXIT,
Thank you for updating your post with the fix
and very glade you got the problem fix
we are here if need us again
happy driving be safe |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
