Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1979 Chevy Truck Fuel Ta...
Auto Repair1972 Gmc C1500 Engine Co...
Auto Repair1993 Jeep Cherokee Fuel ...
Auto Repair2000 Chevy Malibu Surgin...
Auto Repair2000 Plymouth Voyager
Auto Repair2000 Nissan Maxima Car G...
Auto Repair1999 Ford Explorer
Auto Repair2001 Chevy Impala 25 Amp...
Auto Repair2000 Chrysler Van Egr Valve
Auto Repair2005 Chrysler Town And Co...
Auto Repair1988 Bmw 535 Horn By The...
Auto Repair1996 Honda Civic
Auto Repair1998 Lincoln Town Car Ro...
Auto Repair1996 Dodge Dakota Rough ...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Cadillac Deville
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Wed Apr 30, 2008 4:51 am
By edgreene, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
1997 Cadillac Deville V8 Two Wheel Drive Automatic
engine will idel most the time at 625 to 750 rpm without stalling. When put in drive with brake on will stall 75% of the time within 5 min some times just a near stall. No pcm codes. iac,tp,egr,emc,map.maf have all been repalce. pcv has been cleaned,throtle bode has been cleaned. 2 of 4 o2 sencers replaced, vacume holdes stedy at about 15,fuel presure holdes stedy at 40 lbs. Dos not stall well driving.Getting worse afrad to go on planed trip. Whats wrong? Also if pcm is replaced dose it have to be flashed after instalation or can it be done at a deler then instaled?
Find a repair manual for your Cadillac Deville Repair Question.
By Advertisment,
Posted at Wed Apr 30, 2008 1:28 pm
By 2CarPro Ken, Certified ASE Technician
Reputation: 146.7Reputation: 146.7Reputation: 146.7Reputation: 146.7Reputation: 146.7Reputation: 146.7Reputation: 146.7 (147) Give Feedback | Votes: 7
When a egr valve fails it will create an internal vacuum leak causing the engine to stall. Remove your egr valve to make sure the valve is closed and get back too me.
Posted at Wed Apr 30, 2008 7:16 pm
the egr valve has already been replaced. I did today replace the crankshaft sensors and test drove without any stalling it apears at this time that was the problem. You didn;t answer weath or not a pcm has to be in the car when it is flashed or not. Thanks ed
Posted at Wed Apr 30, 2008 7:24 pm
By Buzzsaw, Tech level 7
Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4 (214) Give Feedback | Votes: 11
yes it has to be flashed at the dealer and so does the crank sensors a relearn has to be done
Posted at Wed Apr 30, 2008 7:39 pm
buzzsaw I put the crankshaft sensors in and just drove off everything seems to be fine no dealer relearn.
Posted at Wed Apr 30, 2008 7:41 pm
you will get a ck engine light on, where did you have your codes read at?
Posted at Wed Apr 30, 2008 8:12 pm
I have a code reader. No mil light since replacing ck sensors so haven't scaned for codes. Also it was from reading one of your repliels to others that made me try the ck sensors. thanks for the info Ed
Posted at Thu May 01, 2008 7:27 am
ed greene wrote:
Buzzsaw wrote:
ed greene wrote:
Buzzsaw wrote:
ed greene wrote:
the egr valve has already been replaced. I did today replace the crankshaft sensors and test drove without any stalling it appears at this time that was the problem. You didn;t answer whether or not a pcm has to be in the car when it is flashed or not. Thanks ed
I have a code reader. No mil light since replacing ck sensors so haven't scanned for codes. Also it was from reading one of your replies to others that made me try the ck sensors. thanks for the info Ed
you dont need a scanner for a caddie, it has self diagnostics, push off and warmer at the same time on your heater controls, with the key in the on position, this will allow you to read codes. look in the IP message center for the codes. this will give you all codes for the engine, suspension, and body codes
Posted at Sat May 03, 2008 6:05 pm
I know about the caddy self reader. Not nessary to read codes at this time. As I stated the car is running fine no mil light. We have driven the first 1000 miles of a 8500 mile trip.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
