Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2001 Mazda Mpv Hose Pop...
Auto Repair1995 Mercury Tracer My ...
Auto Repair1998 Pontiac Grand Prix ...
Auto Repair1998 Dodge Stratus 1998...
Auto Repair1999 Nissan Maxima Fan ...
Auto Repair1991 Mercedes Benz 190e
Auto Repair1999 Acura Rl Power Ste...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Cadillac Deville blow motor
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Nov 15, 2008 9:58 pm
By veronica paul, New to the forum
Give Feedback | Votes: 0
1997 Cadillac Deville V8 Two Wheel Drive Automatic 200000 miles
i want to do the job myself but i need the how you do the job
Find a car repair manual for your Cadillac Deville Repair Question.
Posted at Sat Nov 15, 2008 10:09 pm
By bluelightnin6, Moderator
Reputation: 61.9Reputation: 61.9Reputation: 61.9 (62) Give Feedback | Votes: 4
Blocovered in this guider Motor location can change from year to year. It can change with the trim level of the vehicle. A vehicle that has front and rear climate controls may be configured differently than a vehicle that has front controls only. The following are two different repair procedures. One is given because the blocovered in this guider motor is located and accessed in the engine compartment, the other is given because the blocovered in this guider motor is mounted inside the vehicle.
REMOVAL & INSTALLATION
Engine Compartment Procedure
REMOVAL:
Disconnect the negative battery cable.
Remove the cowl cross-tocovered in this guider brace.
With a utility knife, cut the rubber insulator at the guide lines and remove the metal patch plate beneath.
Remove the blocovered in this guider motor electrical connector, cooling hose and mounting screws.
Disengage the blocovered in this guider motor from the case.
INSTALLATION:
NOTE
Failure to maintain a 25 mm clearance (about an inch) betcovered in this guideen the spark plug wires and the HVAC blocovered in this guider motor may result in improper operation or failure of the blocovered in this guider motor.
Install the blocovered in this guider motor fan assembly.
Connect the blocovered in this guider motor electrical connector, cooling hose and mounting screws.
Install the patch plate and the seal insulator patch.
Replace the cowl cross-tocovered in this guider brace (two nuts each side).
Connect the negative battery cable.
Passenger Compartment Procedure
REMOVAL:
Remove the right hand instrument panel insulator.
Disconnect the blocovered in this guider motor electrical connector.
Remove the right hand body hinge pillar trim panel by pulling it away from the from body hinge pillar.
Remove the bolts/screws holding the blocovered in this guider motor cover and remove the cover.
Remove two bolts/screws, allowing the third bolt (nearest the right hand rear corner) of the module to remain in place.
While supporting the blocovered in this guider motor, remove the third bolt.
Remove the isolator from the blocovered in this guider motor flange, if necessary.
INSTALLATION:
NOTE
The impeller is part of a blocovered in this guider motor service kit. The kit is preassembled and balanced. Therefore, do not attempt to separate the impeller from the blocovered in this guider motor.
Install the motor.
Position the isolator on the blocovered in this guider motor flange.
Align the motor with the opening in the bottom of the module and carefully move the motor up and into position.
Install the bolts/screws and tighten them to 17 inch lbs. (1.9 Nm).
Install the right hand body hinge pillar trim panel by pressing it into position until retainers snap into place.
Connect the blocovered in this guider motor electrical connector.
Install the right hand instrument panel insulator.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
