Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Chevy Blazer For L...
Auto Repair2000 Ford Explorer Ball...
Auto Repair2000 Nissan Maxima Stru...
Auto Repair1999 Chevy Cavalier Rou...
Auto Repair2006 Mini Cooper S Rear...
Auto Repair1992 Other Holden Models...
Auto Repair1991 Buick Lesabre Cam ...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Cadillac Catera Oil Pressure Sender
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Thu Aug 28, 2008 2:17 pm
By meow29627, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
1997 Cadillac Catera 6 cyl Two Wheel Drive Automatic 121282 miles
282 miles ago and 30 hours of labor, my car had a big over haul performed by an ASE certified mechanic whom I personally know. Motor torn down and heads send out to be whatever it is that gets done to them, head gasket, manifold gasket, heater bypass valve, timing belt and some bearings all replaced as well as something else I can't recall at the moment. When all was back together, the oil pressure goes very low while at idle. So low that the light comes on. Would this problem be that the car also needs a new pressure sender and if so, where is that located so that maybe my husband can replace it vs. taking it back to the mechanic. There is no GM repair manual by either Chilton or Haynes for this model!! The car is a one owner vehicle and it's in fabulous overall condition inside and out; the only reason I spent the money to have this major repair done to start with and the fact the car is paid for. I'd like to get 4 more years out of it because the mileage I consider relatively low for the year; however, I realize that this model is German made based on an Opel design and it's known to have mechanical problems. What do you think? The oil pressure sender is a $31 part!!! Thanks so much.
Find a car repair manual for your Cadillac Catera Repair Question.
Posted at Thu Aug 28, 2008 2:26 pm
By rasmataz, Certified 2CarPros Master Technician
(13) Give Feedback | Votes: 78
What needs to be done is an actual oil pressure check to determine if its internal problem or just the idiot pressure switch that could be out of calibration.
Below are probable causes:
Excessive main and rod bearing clearances (someone may have installed the wrong-sized bearings or standard-sized bearings on a reground crankshaft). Only 0.001-inch of extra clearance in the main bearings can reduce oil pressure up to 20 percent!
Excessive camshaft bearing clearances (a bearing may have slipped out of place when the cam was installed).
Excessive clearances inside the oil pump.
Leaks between the oil pump and engine.
Oil pump relief valve stuck open or installed backward.
A loose or mispositioned oil pickup tube (too high in oil pan).
A defective oil pressure sending unit or oil pressure gauge.
Low oil level in the oil pan.
Cracks or leaks in the oil galleries or gallery plugs.
Cracked oil pump housing (improper installation).
Oil viscosity too thin for hot weather.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
