Hi twinzino,
Thank you for the donation.
Just to make sure I understand your question correctly,
1. Radiator indicator light is on? That is for high temp or low coolant level? Is there any coolant losses?
2. White smoke from exhaust. Is it white similar to steam from boiling water (cooling system related problem) or slightly bluish?
If oil is found in the cylinder, the smoke should be bluish and you have a problem with the engine valve seals or piston rings. Get a compression test done to find out if any cylinder is below specs.
