Car Repair Questions from 2Carpros.com Car Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Mechanics Ken and Bob
Auto Repair Menu
Auto Repair Questions by Topic
Auto Repair Questions by Manufacturer
Auto Repair Ask a Car Repair Question
Auto Repair Join Our Repair Community
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Repair Manuals
Auto Repair Repair Video Series
Auto Repair Car Sound Problems
Auto Repair Check Engine Light
Auto Repair Brake Replacement Guides
Popular Site Links
Auto Repair Belt Routing Diagrams
Auto Repair Auto Maintenance
Auto Repair How to use Diagnostic Tools
Auto Repair Trouble Code Definitions
Auto Repair Auto Term Abbreviations
Auto Repair Car Safety Check
Auto Repair Hybrid Car Information
Auto Repair Car Owner Tips
  Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Help by Professional Mechanics
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 12,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1997 Cadillac Catera Ignition switch issue
Search 2CarPros.com
Posted at Tue Feb 23, 2010 8:35 pm
By jnewman2010, New 2Carpros Member
Give Feedback | Votes: 0
Electrical problem
1997 Cadillac Catera 6 cyl Front Wheel Drive Automatic 98000 miles
Key turns free but will not engage starter. When switch is turned to off position dash indicator lights(check engine, oil pressure, etc..) stay on as if switch were in run position. Only way to disengage lights is to disconnect the battery. When battery is reconnected interior powers up as if switch is on. I assume switch is bad staying in run position and not engaging starter? I assume the switch has tumblers as it is keyed? Thoughts or ideas?
Find out more about your Cadillac Catera Repair Question: NEED MORE TECHNICAL INFO? Car Repair Manual - Questions by Topic - First Things to Check - How to Car Repair - How Does it Work? - Donate Here
Posted at Thu Feb 25, 2010 1:27 am
By gstacey, Certified ASE Technician
Reputation: 914.4Reputation: 914.4 (914) Give Feedback | Votes: 57
The electrical portion of the switch is seperate from the keyed portion unless the lock cylinder has broken in some way. However, the column needs to be dismantled to get to the switch.
Ignition Switch Replacement - On Vehicle
Removal Procedure
Caution: This vehicle is equipped with a Supplemental Inflatable Restraint (SIR) System. Failure to follow the correct procedure could cause the following conditions:
• Air bag deployment
• Personal injury
• Unnecessary SIR system repairs
In order to avoid the above conditions, observe the following guidelines:
• Refer to SIR Component Views in order to determine if you are performing service on or near the SIR components or the SIR wiring.
• If you are performing service on or near the SIR components or the SIR wiring, disable the SIR system. Refer to Disabling the SIR System.
Disable the SIR system. Refer to Disabling the SIR System in Restraints.
Remove the steering wheel inflator module. Refer to Inflatable Restraint Steering Wheel Module Replacement in Restraints.
Remove the steering wheel. Refer to Steering Wheel Replacement .
Remove the tilt lever. Refer to Tilt Lever Replacement - On Vehicle .
Remove the screw caps from the upper steering column cover.
Remove the screws from the upper steering column cover.
Remove the upper steering column cover.
Remove the screws from the lower steering column cover.
Remove the lower steering column cover.
Remove the inflatable restraint steering wheel module coil. Refer to Inflatable Restraint Steering Wheel Module Coil Replacement .
Remove the ignition switch set screw.
Turn the ignition switch to the ON position.
Remove the lifting magnet from the ignition switch.
Insert a small flatbladed tool into the ignition switch electrical connector hole in order to depress the locking tab.
Disconnect the electrical connector from the ignition switch.
Disconnect the electrical connector from the theft deterent module (1).
Remove the theft deterent module (1) from the ignition lock cylinder housing.
Remove the ignition lock cylinder. Refer to Ignition Lock Cylinder Replacement - On Vehicle .
Pull ignition switch toward the rear of the vehicle and slide to the left to remove the ignition switch from the ignition lock cylinder housing.
Installation Procedure
Install the ignition switch to the lock cylinder housing.
Install the ignition lock cylinder. Refer to Ignition Lock Cylinder Replacement - On Vehicle .
Install the theft deterent module (1) to the ignition lock cylinder housing.
Connect the electrical connector to the theft deterent module (1).
Connect the electrical connector to the ignition switch.
Install the ignition switch set screw until fully seated and not stripped.
Install the lifting magnet to the ignition switch.
Install the inflatable restraint steering wheel module coil. Refer to Inflatable Restraint Steering Wheel Module Coil Replacement in Restraints.
Install the lower steering column cover.
Install the screws to the lower steering column cover.
Install the upper steering column cover.
Install the screws to the upper steering column cover.
Install the screw caps to the upper steering column cover.
Install the tilt lever. Refer to Tilt Lever Replacement - On Vehicle .
Install the steering wheel. Refer to Steering Wheel Replacement .
Install the steering wheel inflator module. Refer to Inflatable Restraint Steering Wheel Module Replacement in Restraints.
Enable the SIR system. Refer to Enabling the SIR System in Restraints.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Check out our other related sections:
ASK A CAR REPAIR QUESTION
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Replace Air Filter
Tune Up
Test Fuses
Toyota Camry Repair
Honda Accord Repair
Acura TL Repair
Honda Civic Repair
Ford Taurus Repair
Toyota Corolla Repair
Ford Explorer Repair
Ford Escort Repair
Advertise 2Carpros.com
  Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Jobs
  Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
