Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1997 Dodge Caravan Wind...
Auto Repair1999 Honda Civic Stuck ...
Auto Repair2003 Gmc Sierra Reduced...
Auto Repair2001 Chrysler Sebring H...
Auto Repair2001 Dodge Intrepid Fuses
Auto Repair1987 Ford F150 Ignition...
Auto Repair2001 Chrysler Sebring E...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Buick Skylark 2.4 DOC engine stumble
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Wed Sep 03, 2008 8:25 am
By krbjt, New to the forum
Give Feedback | Votes: 0
Engine Mechanical problem
1997 Buick Skylark 4 cyl Front Wheel Drive Automatic 120,00 miles
I have a 97 Buick Skylark with the 2.4 4 cyl. I bought it used with this problem.
First of all I used a code scanner from Advanced auto, and it pulled the 2 codes, P0171, and P0172 (mixture too lean, mixture to rich)
The symptoms are as follows...
-when engine is cold, and starting to drive it will hesitate until warmed up
-intermittently driving down the road at normal speed, usually 40 or higher, it will stumble, hesitate, or act like its not running on all 4! (its doesn't do it all the time! If you let off or push harder it will usually clear up, but this happens all the time!
-if you put it in park, rev the engine to around 2500 + RPM's ( it has to tach, so I'm guessing) the RPM's will surge, the only way to stop it is to back off the gas...pushing wide open throttle does not stop the engine surging.
-sometimes if you look at the exhaust, you can tell its running too rich
-it never stalls, and seems to run very good at idle with no load
-the check engine light will obviosly come on most of the time. But it will go off when its running good and the code is cleared
Now here is what I have tried so far!
-new plugs and boots
-new O2 sensor
-new fuel filter
-replaced some vacuume lines that looked questionable, (MAP and PVC tube) others look good
went to junk yard and one at a time tried the following used parts...that did not help!!!
-TPS
-MAP
-ignition module
-ignition coils
-MAF
none of these solved the problem!
The plugs look good, its doesn't burn oil, when it runs good, it has plenty of power. My next thought was tring a new( used) EGR, could that cause this problem?
Any thought or comments would be great...This is my beater car, so I don't want to spend much money, if I can fix it myself! It is in good shape for the year.
Also, the gas tank does have a small leak, but only when its completely full...I can't imagine that is the problem here, but I could be wrong!
Thanks
Find a car repair manual for your Buick Skylark Repair Question.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
