Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1997 Buick Riviera 6 cyl Front Wheel Drive Automatic 215000 miles
I have a 1997 Buick Riviera which does not register the proper level of fuel in the tank. When I first start the car, it registers one amount, however, as I drive along, the guage continues to move upwards. It never registers the same amount when I start it. Any suggestions?
Hi:
It sounds like the float is bad. However, it's part of the fuelpump assembly and both are in the tank. My only suggestion is to have the fuel gauge power supply checked for a voltage problem. If one exist, it will need replaced.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
