Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1997 Ford Ranger 3rd Bra...
Auto Repair1999 Ford Explorer Anoyi...
Auto Repair1992 Pontiac Bonneville ...
Auto Repair1996 Mercury Sable Engin...
Auto Repair1995 Lincoln Continental ...
Auto Repair2000 Dodge Stratus Wont ...
Auto Repair1996 Hyundai Accent Obd ...
Auto Repair2004 Dodge Stratus Cylin...
Auto Repair1991 Ford F150 Kicking S...
Auto Repair1997 Mitsubishi Galant T...
Auto Repair1994 Gmc S15
Auto Repair1992 Chevy Camaro Check ...
Auto Repair1998 Chrysler Sebring Ac...
Auto Repair1997 Volkswagen Passat M...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Buick Park Avenue Fuel gauge
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Mon May 05, 2008 3:59 am
By BJ911, Have Donated
(7) Give Feedback | Votes: 0
Electrical problem
1997 Buick Park Avenue 6 cyl Front Wheel Drive Automatic 35000 miles
I store my car every winter and I disconnect the battery. This spring when I reconnected the battery and started the car the fuel guage needle apparently went all the way around and caught under the pin. It can't move. How can I fix it? Do I need to replace the cluster.
Find a repair manual for your Buick Park Avenue Repair Question.
By Advertisment,
Posted at Mon May 05, 2008 4:20 am
By legitimate007, Moderator
Reputation: 133.9Reputation: 133.9Reputation: 133.9Reputation: 133.9Reputation: 133.9Reputation: 133.9Reputation: 133.9 (134) Give Feedback | Votes: 6
no you should be able to take the cluster out and remove the plastic face shield and gently knock it back over to where its supposed to be
Posted at Mon May 05, 2008 5:00 am
By rhall77, Tech level 6
Reputation: 92.3Reputation: 92.3Reputation: 92.3Reputation: 92.3Reputation: 92.3 (92) Give Feedback | Votes: 3
another way of doing it with out taking it apart is taking it to your local dealer and have them peform a sweep test on the cluster if the tech 2 will communicate with the cluster.
Posted at Tue Jun 03, 2008 4:35 pm
By sherm, New to the forum
BJ911 wrote:
Electrical problem
You can remove the cluster and take the dust cover off then move the needle back with your finger and put it back togather. You have to disconnect the ground on the battery. the key has to be on to move the gear shift to low so you can get the cluster out. Remember when you put it all back together if the Ignition is not in the off position when you connect the ground wire the voltage will spike and you will have do it all over again. It takes about 30 min. after you have practiced a couple of times.
Posted at Tue Jun 03, 2008 8:12 pm
THANK YOU
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
