Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1995 Ford Explorer Fast...
Auto Repair1990 Geo Prizm Head Gas...
Auto Repair2004 Gmc Envoy Changing...
Auto Repair2000 Volkswagen Jetta F...
Auto Repair1997 Ford F150 4x4 Not ...
Auto Repair2002 Mitsubishi Diamante...
Auto Repair2003 Nissan Altima Misf...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 BMW Z3 fuel pump
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Thu Jul 17, 2008 4:38 pm
By wizard49, New to the forum
Give Feedback | Votes: 0
Engine Performance problem
1997 BMW Z3 4 cyl Two Wheel Drive Manual
My car started dying while driving, like it was starved for fuel. It would sputter, I would clutch it and rev it to keep it running and could get from point a to b, even though it might die a few times in the process. I installed a new fuel filter, still experiencing the same difficulties w/1 change...It doesn't seem to do this if I don't run the A/C? I know it sounds weird, so I was wondering if maybe its the fuel pump. Car has just over 69k. Is this a do-it-yourself undertaking? Much thanks in advance. J-Vet in Tex.
Find a car repair manual for your BMW Z3 Repair Question.
Posted at Thu Jul 17, 2008 4:47 pm
By rasmataz, Certified 2CarPros Master Technician
Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4Reputation: 1006.4 (1006) Give Feedback | Votes: 75
If its the fuel pump I don't think you'll make it to point B. Lets try the idle speed control valve, throttle position sensor and the MAF sensor and if it has an EGR valve check that too -won't hurt to check the fuel pressure.
Posted at Thu Jul 17, 2008 5:53 pm
By Dr. Hagerty, Moderator
Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3Reputation: 407.3 (407) Give Feedback | Votes: 9
The fuel pump will present with these issues and it is inside the tank. The A/C issue seems a little weird. Begin the diagnosis with checking fuel pressure and delivery and cleaning of the idle air control valve. By the way, is the check engine light on or off?
Posted at Mon Aug 18, 2008 2:29 pm
By DrWho, Likes cars!
Hi, did you find out what the problem was ? This sounds very much like the issue I have with my car (except the ac part).
regards
Posted at Mon Aug 18, 2008 7:31 pm
The vent valve is often the cause of this issue and the part# is 11-15-7-501-567. It is located on the top of the intake manifold.
Posted at Mon Aug 18, 2008 10:24 pm
Thanks for that Dr. Hagerty. I expect this can cause the car to be ok for a few miles and then to start to misfire and stall.
Posted at Tue Aug 19, 2008 5:56 am
It can cause all kinds of mischief.
Posted at Sun Aug 24, 2008 12:33 am
I am having some problems locating the crankcase valve (trying to verify the part's number so I buy the right one).
The engine I have in my Z3 is taken from a '91 325i. Those engines have a similiar valve as the one you suggested, dont they?
Posted at Sun Aug 24, 2008 4:27 am
When you request advice, there is a reasonable assumption of truth in communication present. You initially reported the vehicle as a stock four cylinder BMW automobile. When there are modifications performed that deviate from the stock configuration, it makes it anybodies guess as to what your problem is.
PostPosted: Thu Jul 17, 2008 4:38 pm Post subject: 1997 BMW Z3 fuel pump
Good luck!
Posted at Sun Aug 24, 2008 5:08 am
Sorry about the confusion but I did not specify anything about what sort of car I had, only that my problems were of similiar nature. The initial description of the problem came from someone with a 4 cyl engine z3. I only posted to check if he had found the solution to the problem.
I have been everywhere looking for someone with a problem similiar to mine and this description seemd to fit it quite well.
Of course I should have mention that my engine is different (my bad) and after more research it seems that my engine (M50) does not have this valve and I am still trying to find the culprit.
Thanks for the help.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
