the filler plug is on the transmission main body casting, on the left side towards the rear. It will probably be an 8MM Allen head or maybe 17mm hex. The fluid is special and may be purchased at the local dealer. Do not use regular ATF or you will ruin the transmission. to fill remove the plug and with the engine running, fill till it runs out the hole. please donate if this is what you needed
