Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1991 Cadillac Brougham ...
Auto Repair2008 Toyota Corolla Mak...
Auto Repair2001 Toyota Corolla
Auto RepairLets All Welcome Our New...
Auto Repair1998 Dodge Stratus 1998...
Auto Repair1998 Land Rover Defender...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 BMW 523 relays
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Dec 02, 2008 8:42 am
By hcloseuk, Likes cars!
Give Feedback | Votes: 0
Electrical problem
1997 BMW 523 6 cyl Two Wheel Drive Automatic 125760 miles
can you please tell where the relay for the abs system is located
Find a car repair manual for your BMW 523 Repair Question.
Posted at Wed Dec 03, 2008 4:00 am
By Dave H, Moderator
Reputation: 97.5Reputation: 97.5Reputation: 97.5Reputation: 97.5Reputation: 97.5 (98) Give Feedback | Votes: 5
ABS/ASC Control Module (A52)Behind glove box.
CAUTION:See ANTI-LOCK BRAKE SAFETY PRECAUTIONS article in GENERAL INFORMATION.
Anti-Lock Brake System (ABS) consists of a hydraulic unit with 4 solenoid switching valves, 4 pulse (speed) sensors, an Electronic Control Unit (ECU), relays and wiring harness. See Fig. 1 .
ANTI-LOCK light on the instrument panel comes on when ignition is turned on. ANTI-LOCK light goes out once engine is started, indicating ABS is ready for operation.
ABS activates at speeds greater than 8 MPH. When vehicle speed is greater than 3 MPH, the built-in electronic test monitor will start checking ABS. If a fault is found, warning light will come on. When ABS light is on, ABS is switched off. Vehicle will then convert to conventional braking.
If battery voltage is less than 10.5 volts with ignition on and test speed is exceeded, ABS will remain off until alternator increases voltage output to more than 10.5 volts. ABS warning light will then go out.
Traction control system, called Automatic Stability Control (ASC), controls slip of drive wheels, regardless of road surface conditions. During a control phase, engine torque is reduced by Digital Motor Electronics (DME) system and throttle control system. If this is not sufficient, drive wheel which is spinning too fast is additionally braked using wheel brake in conjunction with a hydraulic actuator.
ASC light in instrument cluster comes on constantly when ignition is switched on as a bulb check. System is switched on after engine start and can be switched off as necessary. ASC light is off when system is switched on. If ASC light is flashing, ASC control is active. If ASC light remains on, system has switched off automatically because of a fault or was switched off manually.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
