Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1997 Chrysler Sebring
Auto Repair2002 Volkswagen Jetta S...
Auto Repair1998 Chevy Lumina Low C...
Auto Repair2001 Ford Ranger Rough ...
Auto Repair1995 Mercury Cougar Hea...
Auto Repair1988 Jeep Cherokee Last...
Auto Repair1969 Oldsmobile Cutlass
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Audi A6 no heat from heater
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Thu Dec 04, 2008 12:49 pm
By liltremor, Have Donated
Give Feedback | Votes: 0
Heater problem
1997 Audi A6 6 cyl All Wheel Drive Automatic 172000 miles
cant figure out whats wrong with my heater. Mechanic has changed water pump and timing belt, thermostat, and heater core. control valve to heater core is working properly. Lastnite i picked it up from mechanic and it was blowing high heat, this morning nuthin but cold air. even after driving around for an hour. What are we missing?
Find a car repair manual for your Audi A6 Repair Question.
Posted at Thu Dec 04, 2008 3:34 pm
By James R. Weizel, Moderator
Reputation: 138.3Reputation: 138.3Reputation: 138.3Reputation: 138.3Reputation: 138.3Reputation: 138.3Reputation: 138.3 (138) Give Feedback | Votes: 8
Is the divertor damper moving from heat to cool and back to heat when you change the controller?
Posted at Thu Dec 04, 2008 3:42 pm
By ImpalaSS, Moderator
Reputation: 153.3Reputation: 153.3Reputation: 153.3Reputation: 153.3Reputation: 153.3Reputation: 153.3Reputation: 153.3Reputation: 153.3 (153) Give Feedback | Votes: 7
Hello –
To better assist you please let me know if your vehicle is an A6 Sedan, Wagon, Quattro Sedan or Quattro Wagon. And you do have the 2.8L engine……
So I better understand…..why did you have all of those items changed in the first place…..because the car was not blowing any heat?
When they installed the thermostat…..do you know if they made sure the bleeder was on top per the pic below.
How does the temperature on the engine look…..where it normally should, higher, lower, fluctuates?
Was the engine temperature doing anything different before you had the other work performed?
Please go to Auto Zone (AZ) or O’Reilly’s (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery, alternator and starter.
Please answer the above so we can better assist you.
Thanks for the donation
Please let us know if what the final fix was for your car so we can better assist others. Thanks!
Find a car repair manual for your car repair questions.
Posted at Thu Dec 04, 2008 4:08 pm
its a 1997 audi a6 sedan quattro. heater would blow warm air for about 30seconds and then quit. went back each time switching a different part. thermostat then water pump and now heater core. enginge temp is normal. im assuming the mechanic bleed the thermostat when he installed it. they did flush the whole system out. had heat when i picked it up from them lastnite for about 20min. then got cold. this morning nothing but cold air. Ill try to find an autozone around my area and get codes
Posted at Thu Dec 04, 2008 4:55 pm
yes it works
Posted at Thu Dec 04, 2008 7:28 pm
Hello –
Let us know what you find out from AZ.
Posted at Thu Dec 04, 2008 8:17 pm
There's an advanced autoparts store by me and they say they can't run a test if there's no error light or check engine light on
Posted at Thu Dec 04, 2008 8:40 pm
Hello –
It is possible it came on and went off….so it isn’t staying on……maybe they will test it that way. Is there an AZ anywhere else?
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
