Electrical problem
1997 Audi A4 6 cyl All Wheel Drive Automatic 150000 miles
Over the past month my wiper fluid stop squirting out,gradually. Now nothing comes out, checked the fuse and filled the basin up. is there a motor that sends it to the hood or what?thanks
yes there is a small pump normally fitted to the reservoir. If you can hear it working, check that the nozzles are not blocked. Often dry fluid additives can block the nozzle and this can be cleared with a fine pin.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins.Click
here to find out more.
