Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1996 Volkswagen Golf Wi...
Auto Repair2001 Ford Escort Epc Co...
Auto Repair2000 Peugeot 206 High F...
Auto Repair1998 Ford Escort
Auto Repair1997 Ford Taurus Wiper ...
Auto Repair1998 Renault Scenic C.v...
Auto Repair2000 Subaru Outback Dam...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1997 Acura TL Shifter Won't move
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Tue Jul 08, 2008 9:31 pm
By seanlieder, New to the forum
Give Feedback | Votes: 0
Transmission problem
1997 Acura TL 6 cyl Two Wheel Drive Automatic 150000 miles
My car will start fine, but when I try to shift the stick from park to reverse or drive it won't leave the park position. It only seems to do this when it is really cold outside or really hot outside. I have found away around it though. There is a key slot right next to the stick and if i have the car off I can stick the key in and it will release it from park and I can put it in neutral and then start my car. Put as soon as I put it back into park, I have to do this all over again. I shouldn't have to do this. What is wrong?
Find a car repair manual for your Acura TL Repair Question.
By Advertisment,
Posted at Tue Jul 08, 2008 10:12 pm
By KHLow2008, Moderator
Reputation: 217.6Reputation: 217.6Reputation: 217.6Reputation: 217.6Reputation: 217.6Reputation: 217.6Reputation: 217.6Reputation: 217.6Reputation: 217.6Reputation: 217.6Reputation: 217.6 (218) Give Feedback | Votes: 12
Hi seanlieder,
The shifting out of park position is controlled by the interlock circuit. Check if the brake lights are working when it happens. If not, it is the brake switch or it fuse.
When you use manual over riding of the interlock switch, you might be driving without the brake lights.
Posted at Wed Jul 09, 2008 8:55 pm
Thank you for your quick response. I will check my brake lights next time it happens. I was wondering if another problem with my breaks was related to this. During the winter time on a really cold morning my break light on the dash will come on and after a while it will go off when the pressure is taken off the brake. But as soon as I hit my brake it comes back on. I did a google search and found something that sounds like this could be the brake fluid cap or filter. What do you think?
Posted at Thu Jul 10, 2008 3:32 am
Hi seanlieder,
You mean the brake fluid level/parkbrake light?
There should be no connection unless the fluid level is low, just at the point when the switch is about to be activated. When pressing the brakes, a little fluid is drawn into the master cylinder and level drops slightly activating the magnetic strip in the switch.
Check if the fluid level is lower than max but higher than min.
Or is it the brake bulb failure indicator?
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
