Brakes problem
1997 Acura CL 4 cyl Front Wheel Drive Automatic 173000 miles
when im stopped at a light the pedal sometime, not all the time, the brake pedal will start to go down like it is losing brake power. all i ahve to do is pump the bgrake to fix this. what can be wrong
you may have a by-passing brake master cylinder, this is when under light pressure fluid by passes the seals internal of the master cyl and the pedal will drop, with out any sign of leaking fluid.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins.Click
here to find out more.
