Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Transmission problem
1997 Acura CL 6 cyl Front Wheel Drive Automatic 160000 miles
hi
daughter's car...check engine light and D4 lit up while driving....took it in right away...was told it was transmission pickup sensor...made appt for several days later...no driving problems were noted...while driving it the next day she said that at stoplights it felt like someone was nudging the back of the car and when she tried to go at highway speed it took time and more foot on the gas to get it up to speed...oh, and cel and D4 lights have turned back on...could pickup sensor be the culprit or is worst case scenario a new or rebuilt transmsssion?
tks for your time
a conerned dad
If the sensor was causing the fault indication, get that done before you start to get to concerned, electronic transmissions can feel quite strange when they have an issue with a sensor, i would get that sorted first.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
