Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1996 Volvo 850 Front Wheel Drive Automatic 55000 miles
After R & R pcv system problem remains. A compression check revealed 165psi on #5 and 100-105psi on all four remaining cylinders. I purchased the car from a old women in o. Florida who drove it 3-4 months a year while living part time in Fl. and N.Y.
She rarely ventured on the highway and I felt the lack of power was just the result of this style of driving and that a good crankcase flush and some spirited highway runs would clear her out. I can't imagine the rings are wornout at this mileage and again on 4 of 5 cylinders. Any and all advise would be greatly appreciated. I am hoping the 4 cylinders suffer from stuck rings and can be freed up without a topend job.
Please advise.
The low compression could be due to valve leakages so you need to perform a wet compresion test to confirm.
Since the mileage is low, there are some lubs that are supposed to free the rings and clear the sludge, you can give those a try. DO not use those described as engine flush, they won't be of help.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
