Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Mercury Sable Heat...
Auto Repair2000 Pontiac Montana
Auto Repair1992 Toyota Pickup Rapi...
Auto Repair2002 Buick Lesabre Remo...
Auto Repair1998 Chevy Corvette Dig...
Auto Repair1998 Audi A4 02 Replace...
Auto Repair1996 Ford F150 Fuel System
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1996 Toyota Camry Replacing right cv axle
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Goto page 1, 2  Next
Posted at Sat Nov 01, 2008 1:44 pm
By overthetop, New to the forum
Give Feedback | Votes: 0
Drive Train Axles Bearings problem
1996 Toyota Camry 4 cyl Front Wheel Drive Automatic
Right cv axel has been loosened from right side, lock bolt and snap ring have been removed from bearing support bracket. It should pull right out of the transaxle by now and it isn't moving. Am I missing something?
Find a car repair manual for your Toyota Camry Repair Question.
Posted at Tue Nov 04, 2008 12:41 pm
By dsplc, Tech level 3
Reputation: 65.4Reputation: 65.4Reputation: 65.4 (65) Give Feedback | Votes: 2
Yes. You need a long solid pry bar to separate the cv axle from the transmission. If you have a new cv axle, you should see an O ring clip on the shaft side which you insert it inside the transmission. The O ring metal clip is the lock so as the cv axle not to separate/ or the CV axle not from moving from it's place.
Insert the pry bar between the transmission and the CV axle, and use a slight force prying so as to separate the cv axle.
Posted at Sun Nov 09, 2008 2:20 pm
By Malichi, Likes cars!
Im actually working on a 99 Solara, but they are the same body...
On the passenger side the intermediate bar isnt sliding out of the trans like it should. Tried prying at it but all Ive managed so far is to bend the metal flange. Removed the round clip at the intermediate-axle, but the bearing assembly seems to be stuck in the mount...
Attempted to remove the mount from the body, along with the mount for the intermediate bar from the trans...no luck.
Any ideas?
Posted at Tue Nov 11, 2008 1:18 pm
You are right. On the passenger side axle, once you remove the lock bolt and spring clip, you should be able to remove the axle from the transmission.
I asked another mechanic and check some answers around. It is hard to remove the axle because the carrier bearing is seized inside the mount. He removed the mount that is attached to the engine block, pulled the whole axle with the mount still attached and got the bearing pressed out of the mount.
If ever you get the bearing out, put an anti-seized compund for future removal.
Posted at Wed Nov 12, 2008 6:28 am
Alright, thanks, I guess I'll just continue to beat it with a hammer...
Posted at Wed Nov 12, 2008 5:11 pm
By nc01zz, Likes cars!
Give Feedback | Votes: 1
I replaced both front axles on my 2001 Camry. I was about to give up on getting the old ones out and then learned of a device called a "slide hammer" also called an axle puller I think, that you can rent for free (by paying a refundable deposit) at Advance Auto or Autozone. It is a steel shaft with a heavy sliding weight used to jerk the axle out. It has a hook (one of many attachments included) to fit over whatever you can grab onto on the axle shaft. It will beat you to death, but it worked and I yanked both axles out with it. Good luck!
Posted at Thu Nov 13, 2008 6:49 am
Wow, ok, that helps alot NC, I appreciate it. Didnt know they made such a thing (although thinking about it I should have guessed)
I spent yesterday hammering at it, with no joy then either. Im off to autozone this afternoon.
Thanks again!
Posted at Thu Nov 13, 2008 6:43 pm
Get your wife or girlfriend to hold the hook down on the axle (with a towel covering to protect her hand) and have her shout words of encouragement when it finally starts to move...
Posted at Sat Nov 15, 2008 5:52 am
haha! Well I dont know about you NC, but I have friends who want to come over and help me work on my car...you know, that whole 'manly bonding' thing.
I havent gotten a chance to work on the car anymore or rent the ram in the last couple of days, been really busy, but I hope to accomplish this sometime next week.
Posted at Sat Nov 22, 2008 1:44 pm
Well, got the ram, but I'm currently at an impasse.
Where am I supposed to attach the hooks/bracket? I cant attach it at the end of the transaxle, due to the intermediate bar and the uni joint. I would really not want to pull apart that uni joint...
I wish I had my engine in this state already! This is just a picture I found, but of the same engine. The highlighted part is the intermediate bar and the rest of the transaxle.
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
