Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1996 Toyota Avalon 6 cyl Two Wheel Drive Automatic 81000 miles
My Avalon idles about 2000rpm for about 30 seconds to 1 minute even when the outside air temp is 70 degrees or above. After only about 2 minutes will the idle drop to below 1000rpm and finally settling at about 750rpm when at operating temp.
I have already changed the coolant temp sensor and have had a mech analyze the system as a whole.
Any suggestions? or is this idle speed normal?
I had the same thing happen. My first recourse was to to adjust the idle, but only got as far as pulling on the throttle cable under the hood. I then looked in the manual...nothing! Then I came here...so I guess, we just have to let the car idle for more then 2 minutes before we drive away...I noticed the high RPMS too! Its tough on brakes when u back-up...disc brakes squeal. greenphotos@hotmail.com
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
