Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Brake problem
1996 Toyota 4Runner 6 cyl Four Wheel Drive Automatic 234500 miles
Just replaced my front rotors and brakes pads. Easy job, no problems. However, now when the truck is over 40mph, the brakes grab and release. Doesn't matter if I hit the brakes soft or hard - I get a strong vibration. Under 40mph, there seems to be little problem. My tires are in excellent condition with 50K + miles. No sign of an alignment problem.
What should I be looking at now?
Thanks for your help.
"Check the rotors again, could be improperly seated due to foreign materials or rust. "
Thanks. I will pull it all apart again tomorrow. One thing I did not check is the trueness of the rotors. Being brand new, of middle range quality, I just pulled them from the box, cleaned everything, and then installed. Maybe I should have had them checked/turned 1st.
Again, thanks for your advice.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
