Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1989 Mercury Marquis Ca...
Auto Repair2002 Dodge Neon The Car...
Auto Repair1998 Ford Contour Trann...
Auto Repair1997 Chevy Suburban Gau...
Auto Repair2003 Toyota Corolla Wip...
Auto Repair1999 Ford Contour Car W...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1996 Subaru 2.5lt w/ over heating problems
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Mon Dec 10, 2007 6:24 am
By Codger, Likes cars!
Give Feedback | Votes: 0
Engine problem
1996 Subaru 4 cyl All Wheel Drive Automatic 110000 miles
Car was overheating. Temp would climb to the top of the guage and then drop quickly indicating a sticking thermostat. I replaced the thremostat and the system passed a pressure test. Any ideas?
Find a car repair manual for your Other Subaru Models.
By Advertisment,
Posted at Mon Dec 10, 2007 3:27 pm
By mhpautos, Certified 2CarPros Master Technician
Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3Reputation: 464.3 (464) Give Feedback | Votes: 11
Hi there,
Check that the cooling fans are turning on when the temp is high, The radiator may be partially blocked. check these things first.
Mark (mhpautos)
Posted at Wed Dec 12, 2007 6:35 am
right, sorry. I should have mentioned that the fans are working properly and there are no obstructions to airflow.
It seems like the problem gos in a cycle. There is a big time in between occurances where everything runs perfect. Belts are set properly. Not sure what else to say.
Posted at Wed Dec 12, 2007 12:52 pm
Hi there,
Are there any other constants involved with this overheating? Driving conditions?, ambient temp, Check foe a fault set code as well as an over lean mixture can cause overheating problems
Mark (mhpautos)
Posted at Thu Dec 13, 2007 1:22 pm
It almost seems to do it on a schedule. The is driven 20 miles to work then 20 miles home every day. Every other day on the way home it happens but is limited now to just a few blocks of overheating (gets to near the top of the guage then drops quickly 2-3 times). After this, it is fine whether I keep driving or not. Goofy huh?
Posted at Thu Dec 13, 2007 1:58 pm
Hi there,
If we look at what can cause the temp to fluctuate in this manner there is really only 3 options,
!. Your new thermostat is faulty (not the first one to be)
2. The internal core is partially blocked (but this would normally cause a more constant occurrence)
3, Air pocket in engine, (same as above)
Fan switch is coming on when temp is high? not a problem with a switch that is a bit temperamental?
I would discount a water pup problem at this stage, and one last question, is the coolant level constant, no evidence of loosing any coolant prior to an event?
Mark (mhpautos)
Posted at Tue Mar 11, 2008 4:15 pm
By 96sub, New to the forum
The same thing happens to my Subaru...same year/model/2.5... it happened a few years ago too and I ended up having to replace the radiator.
But Recently it started doing it again and last week my car wouldn't start after stalling for a few days when I would start it.
Not sure if it is related to the overheating thing or if I just got bad gas or something but the problem ended up being 3 fouled spark plugs. They almost looked oil fouled. and since this overheating problem has started happening again a thick white smoke comes from my exhaust when I start it...goes away after a while. Although it happens everytime I stop the engine for over five mins or so...even it the engine is at operating temp.
Just curious if you figured anything out with your problem that could maybe help me.
Thanks
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
