I saw a bulletin that might pertain to your problem, bulletin # 73-50-18. It talks about the parking brake not releasing all the way. You can park the vehicle on level ground, block the wheels, tranny in park, see if you can roll the wheels by hand without too much effort. If you have a wheel trying to lock-up, it should be obvious. You can cycle the parking brake a few times, test the wheels again.
It might not be the parking brake, but, if a wheel is trying to lock-up, it shouldn't be too hard to spot.
