Are u sure u have no spark ?
when 1st key on the fuel pump should come on (good or bad crank sensor )
I hate for u to replace the PCM come to find out its some thing else
do every test possible because once u buy the PCM you own it .
check if you have power getting to the fuel pump
and also check the relays
when cranking does check engine light go out or it stay on
checking for codes will help
Need a tool or a tester CHECK IT @
http://www.2carpros.com/affiliate/uid/bmrfixit_1
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
